failing HPOP
m j
BC Canada Eh!
LoL
"better pressure"??
who would give a rats ass about better pressure? I want the pressure that the programming is calling for.
if all you want is "better pressure" then you could probably get it by unplugging a couple of injectors so they dont use any oil
m j
BC Canada Eh!
Now I have never seen a direct comparison between a healthy/new oem hpop and the t500 so I cant go off how much better it would be.. but I do know that its way cheaper to buy a t500 then any quality reman hpop
awesome.
so if your engine had worn pistons and rings your solution would be to add a stroker crank?
All oil threads are hilarious. Hpops suck in any capacity. No big effin mystery.
Some suck worse than others.
I still cant see a 160/30 even tickling a healthy 17° pump but thats on topic. I had issues with 175/80 and race tunes holding pressure especially going uphill. High egts and pressure would fall down to 2200 if you held it long enough. On a 50ish k mile 17° pump.
Southmike
If you change the hpop and you have a e99 pay attention to the gasket.
if it has a screen it will crqck the front cover.
west76
I have a 95 F 350 Powerstroke need to replace the high pressure oil pump do I got to put it in time ?
Sent from my LGLS770 using Tapatalk
