Curtis@Vision Diesel
Joe, you could be right but I thought he had 200% nozzles.
For those interested we are going to be having a 3rd party flow a couple injectors just to get some general numbers out there. Obviously any one can argue that one injector had every trick in the book done and the other was stock or that we didnt put the same nozzle on each or whatever.... But those that don't feed off the drama should be able to see some truth in the data.
400/400 hybrid with fast fuel and oil side mods, about as good as it gets hybrid wise.
400/400 DD with fast fuel and oil side mods, about as tricked as it can be!
We will have the data within the next few weeks though, the injectors are being built and spec'd as we speak then they will be shipped off to a 3rd party with no other data other than 2 injectors to stick in their flow bench and provide flow sheets for.
Anyone have any guess's at which each injector will flow at 3500psi and 2.5ms?
Nope... At least thats not what he was told or told me...
With 300cc of fuel and a 200% nozzle he would have dynoed properly a few weeks ago...
With 300cc of fuel and a 100% nozzle he got what he got.
His truck is not what the Dyno said his truck was.
Sent from my EVO 3D on the East Side
I believe Joe is running a 200% nozzle.
I do have a 100% nozzle. Nothing larger then a 100% was available at the time they were all on back order. Originally I wasn't going to go with a 300 but Mike wanted to try it so I let him.
It was a "rocket science choice" based on the availability of nozzles. Tried getting a set of 200% the last 4 months without going through Swamps? If you had you would realize that isnt possible. Joe needed his truck for the live tuning in Spokane. The nozzles have since become available and Joe should be able to get the proper nozzle installed on those injectors.With a 100% nozzle... Dont know who made that rocket science choice...:morons:
If you don't throw in a 3rd injector in there (say stock or a standard issue hybrid with a 200% tip, or whatever) for a control to compare the data against its almost useless data because there is no way to compare it against known injectors without this.
7.3 drama is soooooo ***king gay
Ya... it is. I drove it. Its a 450-500hp truck...
I say you build it..... Then we can compare it to the best right?
I would like to see a 400/200 DD and a normal 400/200 hybrid tested to....
Mike himself quotes 440cc at 2.5MS is what he can produce.
Welcome to 2009.
