buckster
In the next few weeks, I need to pull my truck apart to do head gaskets and head studs (08 F250). While I'm in there, I plan on doing a few other small mods and maintenance items. I'm trying to line everything up before hand so down time is minimal as this is my daily driver. Hopefully, someone here can help answer the last few questions I have.
What is the thread size for the intake manifold bolts to cylinder head? M8x1.25?
What is the thread size for the exhaust manifold bolts to cylinder head? M8x1.25?
What is the thread size for the exhaust manifold studs to the up pipes?
What size thread and type of fitting is the EBP tube to up pipe connection?
Is the factory hot side pipe from turbo to intercooler stainless or mild steel?
Does anyone sell an aluminum MAF sensor weld on flange for a DIY air intake?
For those that have the posts removed from the intake manifold, what did you do with the items that use to bolt to the top of it? From pictures, it looks like the fuel pump heat shield and maybe a fuel line are held in place by studs that are now replaced with plugs.
What size socket is needed for ARP head stud nuts?
What size socket is needed for the factory head bolts?
Thanks in advance.
Thanks in advance.
