Finding TDC
Rico
San Diego
Can anyone give me tips for finding top dead center for all 8 cylinders. In the process of taking the VC’s off and performing a leak down test
campbellflage
Hudson, FL
Not the most technical of ways, but can pull a glow plug out and put a wire rod in and turn the motor over til it starts to go down
Mesa, AZ
Bump it over till both rocker arms are loose atthe valves/pushrods. That will verify tax compression. Another way is to put your leak down hose in the glow plug hole and put your finger over the end. Bump it till it blows air out.
Rico
San Diego
Right on. Thanks! Figured both but was wrenching solo. Put it off for another day
Mesa, AZ
You can jump the starter relay to bump it over. Harbor freight has staryer buttons for cheap if I remember right
