Jeremy @ No Limit
Ok I'll try to keep this short. I bought a 2006 reg cab that blew a head gasket, kid took it to a local shop, then he decided he didn't want to fix it so they slapped the head and can back on. It sat at their shop for almost 2 years. Coolant on the cylinders of that head rusted bad. So I bought another motor (2007 motor), had a good bit of work done to it and swapped it in. Along with a 4wd tranny since it was a 2wd. 300/150 sticks from Rykan and a billet 366 which I plan to add big LP to. Anyway, I'm at the point where I'm trying to start it. It starts and runs absolutely great.....for about 4 seconds. Then it's like you pull the plug. Just dies. Every single plug and wire was taken loose on the truck when I got it so I've gone over them multiple times. I've even swapped to a 2007 PCM. Still does the same. Here's a kicker.....I can't get anything to connect to it to pull the codes.
Calling my 6.0 gurus. What have I missed?
