TexasA&M
I installed a set of 2.5" Icon springs and a set of Bilstein 5100s yesterday on the front of my '06. We ran out of time to do the alignment cams and trac bar though because we weren't quite sure how to go about either. It turns out that I don't have tools big enough for the trac bar anyway...
So here are my questions -
On the cams, once you remove the top ball joint nut, how do you get the original cam out from around the ball joint stud? Does it just pop out? Any tips/tricks?
On the trac bar, how are you guys installing these things? I need to go out and get a 30mm socket. How are you guys getting 400ft/lbs on the nut? Just a 4' breaker bar on the end of the ratchet? Any tips/tricks for this one?
I'm hoping to knock both of these things out next Saturday and then be done with the front end!
