First time Engine Swap Questions
techiemike
USA
Hi everyone… First time member and poster here, so please excuse any etiquette I am not aware of. If this post is in the wrong place, please direct me!
I am preparing to do an engine swap on my ’05 6.0 F350 SRW that blew it’s head gaskets and decided a cracked head would compliment the situation nicely. Truck is all stock/not studded and had a massive oil leak before hydrolocking itself, so it just makes sense to start fresh with it. This is a 4x4 truck with auto trans. Basically what I’m looking for here, is to absorb as much knowledge as possible from those of you who have done the same procedure at home without access to a lift. I have an assembled long block from Asheville Engines being delivered in a couple of weeks and want to be prepared as much as possible. I did find this short write-up which makes the process sound pretty straightforward:
In my head this job is broken up into 3 stages – Engine Removal, Disassembly of old and swapping parts to new, and then the re-installation. The part I would probably need the most direction in, is that 2nd stage…
With that in mind, please feel free to chime in with any “gotcha’s” that come to mind, and leave me a link to any other write-ups/videos etc. that I should take a look at. This will not be the first time pulling/installing an engine for me, (V8 swap into a Ranger, but different topic….) but definitely the first with a diesel. Really hoping I can get this thing out and back in without lifting the cab.
Here are some questions that first come to mind:
  • 6.0 engine lift plates…Is this absolutely necessary or is this just for convenience? If so, which design is the best, or will any design work? I’m not nuts on the thought of spending $200 on something I’m going to use one time..
  • Any “must have” tools or specialty tools you found were necessary?
  • I plan on re-using any components that are good off of the old engine. assuming all parts are good, are there any components that are “must haves” for you, that make sense to replace anyway? I know there are probably a number of parts that are one-time use anyway, but not sure where to start when looking for these. I do plan on doing 8 new injectors, EGR delete, standpipes/plugs and an oil cooler if the old one looks bad.
  • Bonus: has anyone installed an Asheville rebuilt 6.0? Anything specific I should know?
Any info, links, comments, etc. are very welcome.
Tiha
Super Moderator
Super Mod
Can't help a bunch, but we just used a standard cherry picker with a log chain hooked to the front and rear lift hooks on the engine. It will bend them a little but it came out.
The up pipes, turbo have to come off. FICM, FICM bracket. Can't remember if there was anything else.
This is the second time it came out. First time was for heads and studs. This time it is going into a different vehicle. Going to fix some oil leaks.
Have the same debate about injectors, but honestly replacements are questionable quality. We are just going to wait.
AshevilleEngine.com
Asheville, NC - Nationwide shipping
* CLEAN all of the parts that you plan to reuse, inside and out. Manifolds, covers, etc.
* You can use a chain attached to the lifting eyes to lift the engine.
* Borrow a specialty tool to install front and rear main seals. O'Reilly's, Advance Auto, NAPA and most auto parts stores loan them.
* When you install the front cover, make sure that both of the dowels to line it up are between the block and the cover. One is located at the 2:00 position and the other is at 6:00 when you are looking at the front of the crank.
* After installing the LPOP gears, pack them with Vaseline or assembly lube. This will create suction and start pumping oil throughout the engine immediately.
* When the assembly is finished, fill the oil through the oil filter housing so it starts filling all of the cavities in the engine instead of just going straight to the oil pan.
* Use the injector clamps that we send with the engine and return the old ones with the core.
* Don't over torque your injectors. 28 FtLbs is good.
donny688713
I'm not sure if you're done with reassembling your 6.0 yet. I did the very same about 250k ago. You can get the new injectors at a decent cost. That's what I did. I got them from Accurate diesel. These are brand new, not reman and new design. I didn't buy a short block. I rebuilt it myself. I did put o-ringed KDD heads and all ARP studs and bolts you could get for 6.0. I did change a few things internally, custom ground cam, custom length pushrods. I also weight matched every rod to piston. Good luck, no matter what you read or heard about the 6.0, if you do it right, like FORD did not, it is very reliable. Only use motorcraft sensors. If you replace any, you're not saving everything, doing it more than once. It tried it now. I have a bucket full of sensors to remind me to only get motorcraft .
Sent from my SM-G990U using Tapatalk
