What do I torque my flywheel to on my truck?
Mar 11, 2015 #1 Rmartin-97 New member Joined May 18, 2011 Messages 1,719 Reaction score 0 Location Mcarthur ohio What do I torque my flywheel to on my truck?
Mar 11, 2015 #2 Derek@Vision Diesel New member Joined May 18, 2011 Messages 5,054 Reaction score 0 Location Canby, OR Flex plate or flywheel? Should use new bolts and torque them to 69 ft lbs
Mar 11, 2015 #3 Rmartin-97 New member Joined May 18, 2011 Messages 1,719 Reaction score 0 Location Mcarthur ohio The flywheel has a ring gear correct? That's what I'm talking about
Mar 11, 2015 #4 Derek@Vision Diesel New member Joined May 18, 2011 Messages 5,054 Reaction score 0 Location Canby, OR Rmartin-97 said: The flywheel has a ring gear correct? That's what I'm talking about Click to expand... Flywheel is for a manual truck Flexplate is for an automatic truck. Guessing you meant flexplate, either way 69 ft lbs is the answer and make sure you buy new bolts. They are a torque to yield bolt much like the balancer and head bolts.
Mar 11, 2015 #5 Rmartin-97 New member Joined May 18, 2011 Messages 1,719 Reaction score 0 Location Mcarthur ohio It's an auto truck. Thanks sir
