Pull your thermostats out.
Put some granular dish washing stuff in, Cascade.
Start truck and let it circulate around.
Flush with water and few times after. I just take a heater hose off and hold the hose too it with the radiator drain off.
This tap water is bad thing is a hoax unless your water has a high mineral content, as in you are on a well then you are most likely on a softener or filter.
I have ran tap water in everything and have not had a problem. Hell I still have the stock housing on my 96 Impala. Most of the time it has had straight tap water and water wetter.
Really? I don't know the science behind it, I have just been told by a few people to not use tap water, and just assumed it wasn't good based on that. I guess the distilled water was just a comfort thing. Lol
My next flush I do plan on pulling the t-stats and doing a intense flush. A lot of straight water flushing after a few more rounds of restore. It honestly seems like this crap is never ending.
When you say granular dish washer stuff, do you literally mean buying the box of dry washer solution and pouring it straight inthe degas bottle and letting her rip? How much dry granular stuff do you recommend per flushing? How many times should I do this, or is that based simply apon how much crap I see comming out?
Sorry for the 20 questions, just never used the dish washer solution method before
