Pwnm30rdi3
For sale is a full compound turbo kit. This kit is drop in! This combination made over 90 PSI boost and over 615HP with 300/200 injectors, FUEL ONLY.
This is a drop in kit. No heavy fabrication required, just relocate batteries and cut the plastic fender liner! Everything needed is included. It just works. I've spent 100's of hours making sure this set-up is perfect. It has less than 3,000 miles on everything. I haven't had this set-up up and running long. Block is cracked, so I am cutting my losses.
I ran this with factory AC & kept the windshield washer reservoir.
Here is a general Parts List:
I have over $10,000 invested in this set-up.
I would like to get $6,500 + Freight.
- S400 - 82/88 Atmospheric Turbo - Welded V-Flange (From James Barder)
- S300 - 62/66 High Pressure Turbo - Welded V-Flange & Upgraded Center Section (James Barder)
- T4 - Irate Up Pipes w/ Additional External Wastegate
- TurboSmart 45mm Wastegate
- Mishimoto 6.0 Intercooler w/ Mounts
- Custom Full 4" Down Pipe
- Modified Valve Covers
- Modified Coolant & Windshield Washer Reservoir Bracket
- (Optional) Oil Pan with -12an Drain Fitting OR (Optional) Scavenger Pump
- 3" Riff-Raff Aluminum Intake Plenums
- All Hose Fittings for Oil Supply & Return (Premium Stainless Braided Lines)
- All Custom Intercooler Piping (Has been professionally TIG Welded and Powdercoated with additional Powdercoat Clear Coat)
- Washable Performance K&N Air Filter
