For Sale: RARE! 7.3 OBS Compound Turbo Kit
Pwnm30rdi3
Indianapolis, IN
For sale is a full compound turbo kit. This kit is drop in! This combination made over 90 PSI boost and over 615HP with 300/200 injectors, FUEL ONLY.
This is a drop in kit. No heavy fabrication required, just relocate batteries and cut the plastic fender liner! Everything needed is included. It just works. I've spent 100's of hours making sure this set-up is perfect. It has less than 3,000 miles on everything. I haven't had this set-up up and running long. Block is cracked, so I am cutting my losses.
I ran this with factory AC & kept the windshield washer reservoir.
Here is a general Parts List:
  • S400 - 82/88 Atmospheric Turbo - Welded V-Flange (From James Barder)
  • S300 - 62/66 High Pressure Turbo - Welded V-Flange & Upgraded Center Section (James Barder)
  • T4 - Irate Up Pipes w/ Additional External Wastegate
  • TurboSmart 45mm Wastegate
  • Mishimoto 6.0 Intercooler w/ Mounts
  • Custom Full 4" Down Pipe
  • Modified Valve Covers
  • Modified Coolant & Windshield Washer Reservoir Bracket
  • (Optional) Oil Pan with -12an Drain Fitting OR (Optional) Scavenger Pump
  • 3" Riff-Raff Aluminum Intake Plenums
  • All Hose Fittings for Oil Supply & Return (Premium Stainless Braided Lines)
  • All Custom Intercooler Piping (Has been professionally TIG Welded and Powdercoated with additional Powdercoat Clear Coat)
  • Washable Performance K&N Air Filter
I have over $10,000 invested in this set-up.
I would like to get $6,500 + Freight.
m_j
where is the like button.
good luck with the sale. nice work
Pwnm30rdi3
Indianapolis, IN
Thank you! I have way too many hours in this kit. I will even hand write install instructions for whoever purchases this kit. This was probably the most fun set-up I ever had the chance to drive. I would choose to drive this over my 2012 GT Mustang because of how much fun it was. Whoever buys this kit is getting a hell of a set-up!
Kit is still for sale, $6,000 + freight.
jjsalz
Nowhere
A couple questions on this one, what gauge wire did you use for the battery relocation? I would need to do the same and if I'm going all the way to the bed then I need it properly sized. Secondly, would you consider adding the relocation supplies to the sale? And thirdly, how well did this setup clean up your 300/200s? Sorry for all the questions but obviously this is a large chunk of change and I plan accordingly. Thanks
Pwnm30rdi3
Indianapolis, IN
I'm more than happy to answer any and all questions!
I probably over-sized the wire used for the battery relocation. I used 2/0 welding wire and then bought some corrugated plastic wire cover for further protection.
I would be more than happy to throw in all the battery relocation supplies, except the battery boxes themselves. As I accidentally cracked the plastic battery boxes when I moved a couch with the truck last summer (I would suggest buying aluminum battery boxes if you decide to relocate your batteries to the bed). Regardless, I believe I have about 22' of wire that I can include in the kit. The wire is already terminated with 3/8" copper eye-lits for easy install on the battery posts.
This set-up cleaned up the 300/200's very well. With the wastegate only loosely tuned, I would get a stream of heavy grey, not black, smoke. I'd say that a 50 shot of N2O would clean up the smoke to a haze. This setup is very similar to the user on this forum known as "Blowby". I think he cleared 1000hp with 400/400's and N2O.
I'm also selling my set of 300/200's if you are interested, I'd be more than willing to make a package deal.
psmike
Calif
WOW would love to do this to my 97... just don't have the funds.. would love to see more pics please.. an good luck with the sell someone is getting a good deal..
Pwnm30rdi3
Indianapolis, IN
I had hundreds of pictures and lots of videos at one point. I lost the phone that had all of my content and I am now left with only a few pictures I transferred to my computer. I'll be sure to look for more pictures!
