Ford Called me with a Estimate what should I do?
rustbucket
Fallon, NV
IPC is on the driver side head by the fuel bowl. Its few inches forward of where the hpop line is plumbed into the head.
Charles
Would it be possible for no one to ever refer to the icp sensor as the injection control pressure ever again?
ICP = injection control pressure...
ICP SENSOR, is an actual object.
ICP is a pressure reading depicting the state of the high pressure oil system. You wouldn't explain where the injection control pressure was, nor would you replace it, nor would you buy one at ford or any other such nonsense, unless you want to have a philosophical conversation about the injection control pressure and what it means to you.
If nobody pays enough of a damn to their syntax for something like ICP vs ICP SENSOR, then how will anyone know what the F you're talking about?
If you say the ICP looked good, I assume you measured the pressures and everything looked good, whereas one of these ***tards calling the ICP sensor "the icp" might think the physical ICP sensor itself looked good, like good connections, no frayed or damaged wires, no oil flowing out the connector, so on and so forth.
ICP...... = INJECTION CONTROL PRESSURE
ICP SENSOR.... = injection control pressure SENSOR
And for the love of God.... SOMEONE fix the G'damn "Green Highlight" glossary thing on the site to reflect that.
Done.
mclarengts
Warner Robins
So is the ICP easy to spot, or will I have to do some digging, also is the ICP plug and play, or do I have to splice wires? Today Imma go to Ford dealer and pick up a ICP or place a ICP on order
Charles
Remove the passenger's side high pressure oil line from the head and insert the #5 ORB fitting into your ass. It will be a very loose fit for you, but it doesn't need to seal for this procedure.
After inserting the hose end into your ass hole, have a friend, or use a remote start to fire the engine.
You just found the ICP.
Aaron S
Mean, but damn that was funny.
I hope mcclaren was being sarcastic.
SledDogg
Ann Arbor
**** that was funny ****........let us know your real feelings!!!!!
I bought a FORD ICP SENSOR off ebay for $92 shipped. You'll need a crow's foot socket to remove old and install new one. Try to swap them as fast as possible to reduce the amount of air getting into the system. Will take a while to get all air out once it's fired back up.
Riff Raff diesel sells a OEM BOSCH fuel pump for $150....awesome deal. I changed mine on the road in a Waffle house parking lot in less than 20 minutes.
My truck came alive afer installing a new fuel pump.
JD3020
Farmersville/Dayton, Oh
False, this guy would change it.
LOL LOL
mclarengts
Warner Robins
Good stuff I did not know you were so Anal about your ICP. Sound like you know all about findind the ICP. By your well detailed description I know you've tried this..
purpleheart350
Rokwall, Tx
Steering Box was previously mentioned ? where?
Sunday night my steering gear broke. Well also I was having issues with vibration when towing up hills and loss of power. So when my gear broke I had no choice I towed it to ford. The guy called me about 20 min ago and said..
The Steering gear is $720 parts and Labor, the gear is $455, but im going with the RedHead unit $357
Right here, but if you are talking about where I bought my box then it was here in Plano, tx (Dallas area)
