Ford Rules 6.0 build
ford rules
Got some stuff done on my truck this weekend. Both heads are back on waiting on my valve covers to be painted and to get my intake back.
What is your guys opinion on leaving the heat shield out for the uppipes I'd like to leave it off. Input is appreciated.
Redneck6.0L
Lookin good. Leave the heat shields off It'll make it a lot easier to work on down the road if you need to get at the ipr
Cold Roller
Oakbank, MB
If you cut the heat-shield it will still do its job and be easy to remove. On my latest truck the previous owner or his mechanic did it. I didn't even notice until I went in to replace the HPOP. I didn't take a pic of it, but the red marks on my last engine show where the cuts were made. If you ever need to get to the IPR, it makes it a lot easier.
Cold Roller
Oakbank, MB
Since I can't edit it into the last post, here is what it looks like with an IPR socket on it and 1/2 of the shield removed. With the Degas, FICM and the rear FICM support out of the way, you can see the edge of the remaining shield in the background.
ford rules
I might cut it in half an see if I like it. I'm liking the idea of just getting it out of there all together looks cleaner. Plus I just ran it over with our skid steer on accident so it's a little smashed now.
ford rules
Just saw this thread, thanks again for the business buddy. Cant wait to see this all get together and tear up the streets!
Thank you Jared, great customer service and fast shipping ill order from you guys again for sure!!! Now I just need a shirt and some stickers!!:thumbsup:
ford rules
Got a little done this weekend, prepped and painted the bottom of the cab looks pretty good I think.
Just waiting on my manifold then I can drop the cab back down and finish it up.
Mdub707
Mohawk NY
Oh man that looks awesome. Wish I had the space/equipment to do this myself. My underside on my truck needs a good cleaning/painting. Coming along nice!
ford rules
Thanks^
Got all my parts painted last night gonna install them tonight, then just wait for the intake and drop the cab.
ford rules
Thanks guys!! Probably gonna drop the cab this weekend wire up the fuel pump and run my fuel lines.
Any input on how to wire the pump is appreciated I want it to turn on and off just like the factory one would. I'm thinking find the signal wire for the factory fuel pump and just use that with my own heavy duty relay and wires?
Some pics of the painted parts.
ford rules
Just the stocker with a dieselsite wicked wheel.
Any input on fuel pump wiring guys? Much appreciated!!
ford rules
So just use the hot wire from the stock pump as the signal wire then?
Dropped the cab down tonight also should have it all buttoned up this weekend besides the intake manifold.
