F250stroker08
I'm trying to replace a front drivers side u joint that I broke sled pulling but am having trouble removing the hub. Any suggestions? Thanks.
Ok. I got everything off but cant remove the axle shaft now. Any tips for removing this?? Thanks.
don't you still need to set the correct depth with re-installing the seal??
the other use of that tool.
