What are the #'s I should be seeing on the SCT. idle, Cruising 60-70, WOT?
Aug 26, 2013 #1 Jmoore1225 New member Joined Dec 30, 2011 Messages 334 Reaction score 0 What are the #'s I should be seeing on the SCT. idle, Cruising 60-70, WOT?
Aug 26, 2013 #2 tbsimmons New member Joined Aug 5, 2011 Messages 2,221 Reaction score 0 Location Bakersfield, CA Its in KPA if I remember right.
Aug 26, 2013 #3 WoodBoy New member Joined May 23, 2011 Messages 1,894 Reaction score 0 Location Alabama Megapascals (Mpa) If you are on a tune that runs 5000ish psi at idle high 34.X to 35ish. 5750-5800psi tune at idle is around 38mpa IIRC. Cruising is anywhere from 65-85. I think backpressure is in Kpa Last edited: Aug 26, 2013
Aug 27, 2013 #4 Jmoore1225 New member Joined Dec 30, 2011 Messages 334 Reaction score 0 Thanx guys, mine is dead on the #'s you gave woodboy. I'm only running Gearhead street.
Aug 27, 2013 #5 tbsimmons New member Joined Aug 5, 2011 Messages 2,221 Reaction score 0 Location Bakersfield, CA Stupid live wires. You have to think when you look at stuff.
Aug 27, 2013 #6 Jmoore1225 New member Joined Dec 30, 2011 Messages 334 Reaction score 0 I know, not to mention how ugly it is....
Aug 27, 2013 #7 tbsimmons New member Joined Aug 5, 2011 Messages 2,221 Reaction score 0 Location Bakersfield, CA Mine stays in the console. I watch stuff with an Edge Insight. Cant see as much, but what do I care if the truck running good.
