what a mess
what could cause this? thanks for the help 08 6.4
the truck has erg delete yes and not sure its on craigs list i was goin to go look at it
Have same issue goin on a truck now. If the injector lines or fittings were leaking fuel would it pass the high pressure test on the IDS? Just wondering a direction to go for diag.
It passes the high pressure fuel system test. Any ideas how to isolate the problem injector or line if this is the case?
I would put dye in the fuel bowl and start trying to figure out where its coming from. Mkst likely is the seal on the hpop. However, i have had injector bodies leak, had guys overtighten the jumper lines and *** up the flare or crack them, and i have never seen it personally, but the plugs on the ends of the rails could leak.
seal on the HPOP or HPFP, I was told on my page about this same issue that there is no correlation with the HPOP on these engines....
