94.5stroker
Ok so I have a pretty steady leak coming from somewhere in the valley. And after searching I don't know how many HELP fuel leak! threads I have come to the conclusion there are just way to many possible candidates for a leak. So my idea is that since I am taking the fuel bowl out to find/stop the leak I am going to replace everything. So I am going to order the master o-ring kit for the fuel bowl as well as the seals for the fuel rail plugs(which aren't leaking but if Imma pay shipping I wanna have them laying around) the seals for the banjo bolt, and new hoses for all the lines. My question is, is there any need to order the pre-cut OEM style hoses that are offered, other than the obvious advantage of not having to cut them? They are 5-10 dollars for 2-3 inches of 3/8's fuel line that you can get for 1-2 dollars a foot from your FLAPS...... The only thing I have found is that they list it at 300 psi which I don't understand cause this is a mechanical fuel pump, is that really necessary? Maybe with a CP3 in a common rail but I can't imagine the mechanical pump supplying that much pressure. Can I just buy bulk 30-50 psi fuel line and save a bunch?
Sorry so long, also is there anything I have missed that I should get, or anything I need to know going in to this? I can't really find where the leak is coming from since I am at school I don't have any sort of mirror or way of really finding it, so I figured I would be proactive and just cut out as many options as I can.
Thanks in advance
Nick
Edit: I am gonna try and make sure it isn't coming out of the weep whole two while I have it running just in case I need to buy a fuel pump as well, I am just hoping replacing the major know leak spots will take care of it.
Thanks in advance
Nick
