Fuel pump? P0087 and clacking noise?
94forddiesel
Ashaway, RI
Well when I get back home from work, I'm going to pull the head off and see if I can find out what happened. Hopefully it's something stupid and not melted pistons.
groove
Okanagan BC
Holy sheet man.. What did the noise sound like? I just rebuilt my engine and thought I tossed a torque converter. Replaced it and still have a noise that sounds like a nut in the flex plate. Doesn't do it on cold start, needs a little run time first.
I didn't replace the HPFP either....
Hope your pistons are all good, keep us posted
94forddiesel
Ashaway, RI
Almost sounds like a knock / bearing let go but I think it a fuel related knock it's weird when it warms up the smoke clears and noise goes away. Once I get home I'll dig into and let y'all know what I find.
groove
Okanagan BC
Well, looks like my noise is the HP turbo eating itself. Cold start no noise, take it around the block and is rocks in a can..P2563 code too.. Ugh
94forddiesel
Ashaway, RI
94forddiesel
Ashaway, RI
Well 6.4 is on hold. Time to get the spool bus back the 7.3 goes to the machine shop tomorrow. Then I will find a short block for the 6.4.
