Garrett 38R 1.0 vs 1.15 dyno test
CSIPSD
Bend, OR
Lol, they did not change anything spec wise.... Sooooo unless the tech guy at Honeywell lied to me, you are confused and mislead.
I did turn over a new leaf, thank you for noticing. That new leaf however still carries no tolerance for people making other people dumber because they don't know what they are talking about. Now, if you have some before and after CAD or solid worxs drawings of the changes, or some diemensional differences that you collected, please, post up. If you are gonna continue to base your theory off facts like "so and so said its louder and it smells different" well then please stop.
Thanks joe
Of course your right Steve...
Honeywell spent thousands of dollars to retool the turbo, just because they thought it would pay off for the 30 units a month they might sell...
Tom S
I also would be more inclined to think they made a change then not given information I have. I was reading endlessly about the 38r right around the time they were out of production. The change could have been something small like getting tolerances back dialed in or something.
CSIPSD
Bend, OR
Nope Tom... Steve said they didnt change a thing, they just spent thousands of dollars because they like to spend money... And Honeywell is known for just laying it all out there.
Powerstroked162
On Da Juice
Wa. State
Please reference post #52.... then when finished, please see post #56.
Post up what you know, not what you think. Thanks Joe
average
Central PA
Big Bore
9000ft in the CO Rockies
So am I reading correctly that the "retooling" was not a "redesign" or change of spec for the turbo, but a bringing of tooling back into original spec? Could this maybe be a point of misunderstanding?
CSIPSD
Bend, OR
Nope... Steve said nothing was changed, that means nothing was changed...
Steve's always right and knows everything.
Diezel Dawg
Cheney, WA
How about a retooling of the machine that makes the housing castings, rather than a retooling of the turbo itself
Sent from my EVO 3D on the East Side
Power Hungry
Winder, GA
I read you said no significant difference, but how noticeable was the difference in lag/spool with the different housings (curious for possible future use with my manual trans)? How well does the 38R hold up at these levels? What's the elevation at your dyno PHP?
These to-the-point, extremely informative threads with actual numbers and documentation are awesome, thanks!
Our elevation is about 800 Ft. I didn't notice any difference in lag/spool between the housings while running loaded on the dyno. Truck feels very responsive with both housings and the dyno didn't show a significant loss with the 1.15 housing, so I'd say you could go either way.
My biggest thing between the housing was that the cost factor seemed to outweigh any perceived EGT/Backpressure benefits of the looser housing. The 1.0 housing runs fine at this point with no surging as of yet. Now, I have not put a trailer on the back or anything like that so I can't say 100% that there isn't any surge with the 1.0 housing, but I'll wait until we get the new tranny installed before I proceed any further since the tranny and converter is going change the loading on the engine. We'll fine tune after that and if it is deemed necessary we'll change back to the 1.15 housing. At this point, I don't see the need to.
Lowdown89
Travelers Rest , SC
Twisted said they were shipping the trans this past friday so hopefully it will be in your hands ASAP! Im bringing it as soon as is in my possession
TARM
Bill.
With that dyno how much can you load it? Couldn't you simulate weight of pulling a trailer?
Power Hungry
Winder, GA
I can put as much load on it as I'd like. I just have to watch as the heavier I load the dyno, the hotter the brake gets and the less time I can run it. Not a big deal though. I've put a 25000 Lb load on the dyno before and damn near stalled the truck. LOL
Hotrodtractor
Mingo, Ohio
I was on a Mustang load cell back in 2007 - we put 30K (I think?) on the load - and I held it something like 450hp for a full minute.... that load cell was HOT... and you couldn't see across the shop for about 10 minutes after that..... with overhead doors on both sides of the shop open... LOL I so wish I had a picture/video of that.
Power Hungry
Winder, GA
What size Mustang was it? MD-250? MD-500? We have an MD-250 and I've done 420 HP full throttle loaded tests on my 6.0L for a minute or two and it gets pretty warm. Have to keep fans on the brake to help avoid any temp concerns. :D
Hotrodtractor
Mingo, Ohio
I'm not sure what model it was - but it was a single load cell in a pit and in the middle of the afternoon at a dyno day so it was getting worked pretty good. That was back in 2007 and my first time running a "big" turbo on a dyno - learned an awful lot since then. LOL
sniper_101
rural SK
Thanks for the detailed insight, greatly appreciated! Keep us updated!
PS - Nice truck, and numbers Lowdown89 :drool:
