03 tx pwr stroke
My truck started having long/hard starts when cold. Would start, then die right away. Then long crank, start and die. Long crank again, and finally start and stay running. Would run like crap until warmed up. Was thing maybe injector stiction or something along those lines. Then truck started hesitating from a stop and now bogs down severly on anything other than very gentle acceleration. I pulled codes with my SCT and got 3.
P0336
Crankshaft position
(ckp_sensor ckt A range/performance)
P0341
camshaft position A ckt intermittent
(b1 or single sensor)
P2291
injector control pressure too low
-engine cranking
Talked to Dorian with PSE and he thinks HPOP is on the way out.
Then tonight, I went to start the truck after work, and BAM!!!! Dead batteries. FML!!!!:doh:
Was planning on taking it to PSE next month. Why can't this sht happen at a convenient time?
Looks I may be :walkin: until then. uke::flush::shrug:
P0336
Crankshaft position
P0341
P2291
-engine cranking
