Going to try a new setup
Erikclaw
Central CA
I need a little help, the power under the curve. What exactly does this mean? I have read and heard people say this, but I really don't understand it. From what I gather it means it makes more power under the curve than the graph states? So it doesn't read accurately? But that makes no sense so I have to have it wrong.
Jeff@Spartan
Georgia
The power below peak power. Our trucks typically have a very flat curve, therefore power under the curve is pretty damn close to peak power. Most tuner only trucks hold above 500 horsepower for a lot of RPM.
Dzchey21
wyoming
every dyno graph has a "peak" hp, thats where the number comes from, thats the maximum power that was made during the run.
Power UNDER the curve is basically "average" hp
So if you look at your graph from any dyno, you will notice that the graph looks pretty flat, thats a good thing, that means that before and after peak power, its still making good power.
Now go look at about any cummins or a big turbo'd trucks graph you will see that the peak power looks more like a mountain than a table top, thats considered to be "peaky" power, which isnt as good, sure the power might be better than some, but its not always a good thing. The key is to make the graph look as flat as possible with a decent "peak" number
Generally speaking a 600 peak hp dodge will be slower than a 600 peak hp powerstroke, simply because you cannot keep the engine at "peak" power all the time, unless you had a cvt trans. So durring shifts when your above and below the peak hp the average hp isnt as good.
mike@haller's
Cheyenne, Wyoming
a big peak number is cool for winning dyno events, but having power through out the whole curve is where you get you driveability. Here is a graph of the same truck, before and after some gate tuning. Same peak number but the blue line shows the power coming on way sooner. and is now alot funner to drive.
Dzchey21
wyoming
right, good example.
if i remeber right they start making 500 hp @ 2200 rpm maybe even sooner and dont drop below 500 hp till after 3500 rpm when peak power may only be 560-570. so the power difference is only 50 hp from peak to average
Now look at a dodge alot of times they wont even make 500 hp till say 2500 and then they drop below 500 hp @ 3000
Dzchey21
wyoming
nice visual aid LOL
mike@haller's
Cheyenne, Wyoming
here is one more to show how dodges are peaky. The blue line is a twin turbo commonrail dodge. The red line is a 6.4 with max powers. The dodge was very smoky and spooled really slow. The ford lit up and just did work.
JDub
Hooper, Utah
And that Ford will destroy that Dodge on the street!
Erikclaw
Central CA
Thanks guys, I get it now. I understood the peak power and how a flat curve is way more desirable than a peaky one. The power under the curve term threw me.
Jeff@Spartan
Georgia
I think Dustin is still on the stock intercooler with no issues. I still have the stock one as well. 120,000 miles. I don't make the power Dustin makes though.
WoodBoy
Alabama
I highly doubt you will put enough pressure to bust the plastic in the intercooler.. Schedule 80 PVC pipe is rated for ~167psi operating pressure (6" diameter) and it isnt even ribbed or etc. like the intercooler.
