Got Oil? Lol!
V-Ref
9 miles high @ 550 mph
Top secret skunkworks Area 51 Compartmentalized Access need to know only if ya gotta ask you don't need to know stuff right there!
Southmike
I forgot it was a stealth ...Dual iprs?
That would be the only addition i can think of...
other then the multi lines.
vanderchevy18
Benton, Ks.
There's a line to each head, a balance line between the two pumps, a suction line for the rear pump, and a return line going back to the resivour. The rear port on the back pump is plugged. The blue hose goes up to where the oil pressure sensor is to draw oil to the rear pump. The fitting in the center block towards the bottom of the picture is the return to the resivour. The stainless hard line is the balance line between the pumps.
PSD715
Alamogordo NM
The steel line is the balance line? How does it connect to the rear?
I have 4 lines, and I don't really like it.
