Glow Plug Monitor
Glow Plug Control, Comprehensive Component Monitors, and Wait to Start Indicator—California
The California glow plug system is composed of a glow plug relay, glow plug shunt strips, shunt strip monitor circuits, glow plugs, glow plug light, and the associated wiring harness. The glow plug on-time is controlled by the Powertrain Control Module (PCM) and is a function of oil temperature, barometric pressure and battery voltage. The PCM enables the Glow Plug Relay, which drives the shunt sense strips, which in turn drive the individual glow plugs. Glow plug on-time normally varies between 1 and 120 seconds. The power to the glow plugs is provided through the Glow Plug Relay directly from the vehicle battery. The PCM monitors through two shunt monitoring circuits, one per bank, and detects glow plug functionality.
Glow Plug Relay Control Circuit Check:
DTCs P0380 – Glow Plug Relay Circuit Check
Monitor execution: Continuous (Background 25ms – 50ms)
Monitor Sequence: None
Sensors OK: Not Applicable
Typical Monitoring Duration: Internal to Chip.
Typical Glow Plug Module Control Circuit Check Entry Conditions:
No Entry Conditions
Typical Glow Plug Module Control Circuit Check Malfunction Thresholds:
Internal to chip checks for open circuit, short to ground, and short to power.
Glow Plug Monitor Operation:
DTCs:
P1391 – Glow Plug Bank 1 Failure
P1393 – Glow Plug Bank 2 Failure
P1395 – Absolute Voltage Drop Across Bank # 1
P1396 – Absolute Voltage Drop Across Bank # 2
Monitor execution:
P1391 – Continuous
P1393 – Continuous
P1395 – During the absolute test
P1396 – During the absolute test
P1395 – Greater than 30 seconds.
P1396 – Greater than 30 seconds.
Typical Glow Plug Monitor Entry Conditions:
P1391 – Battery Voltage (IVPWR) is between 11.5 and 14 Volts and Glow Plug Duty Cycle is 100%.
P1393 – Battery Voltage (IVPWR) is between 11.5 and 14 Volts and Glow Plug Duty Cycle is 100%.
P1395 – Battery Voltage (IVPWR) is between 11.5 and 14 Volts, Glow Plug Duty Cycle is 100%, and Glow Plug on time is greater than 30.5 seconds.
P1396 – Battery Voltage (IVPWR) is between 11.5 and 14 Volts, Glow Plug Duty Cycle is 100%, and Glow Plug on time is greater than 30.5 seconds.
Typical Glow Plug Monitor Malfunction Thresholds:
P1391 – When the Bank #1 shunt signal is lower than a specified value (.66 volts) the fault is set.
P1393 – When the Bank #2 shunt signal is lower than a specified value (.66 volts) the fault is set.
P1395 – During the absolute test a fault is set if the voltage drops below a specified value (155 A/D counts) on Bank #1.
P1396 – During the absolute test a fault is set if the voltage drops below a specified value (155 A/D counts) on Bank #2.
Glow Plug Wait to Start Light Operation:
DTCs:
P0381 – Glow Plug indicator circuit malfunction
Monitor execution: Continuous (Background 25ms-50ms)
Sensors OK: Not applicable
Glow Plug Light Wait to Start Light Entry Conditions:
Glow Plugs Enabled
Glow Plug Light Wait to Start Light Malfunction Thresholds:
Status internal to chip
