Gray haze at idle
Dzchey21
wyoming
Its more rpm based than anything. I will have to look but its something like config 0 temp 2 is cold coolant thats about the only one that does anything
drunk on diesel
how did I miss this thread? :confused:
my 350 is a really dirty truck... it's heavy, so that doesn't help, but I can put the same exact tune on my other trucks or my friends trucks, and the work truck is always just dirtier across the board.
time to give it a little more RP and see what's what
Stroked777
Casper, Wyoming
howd you make out changing the RP/
Stroked777
Casper, Wyoming
haven't even had time to mess with it... finally washed the truck off for the first time in 4 months yesterday (and it promptly rained today)
its good to check the forecast befoee you wash and wax it, i dont bother if its gunna rain in 3 days lol,
i just upped my RP at idle so ill let you guys know how i make out, i bumped it by 500 psi when the coolant is cold on the table dustin said to adjust
Stroked777
Casper, Wyoming
well i changed the config0 temp 2 table to about 6k RP and idle up to 1300 rpms and i just went out to try it, coolant is 95 F and outside is 15 F and RP stayed at 4.8k psi, so no change there unless coolant needs to be colder than that
Dzchey21
wyoming
Yep coolant needs to be below 75 i think
Someone told me that the latest update for MCC has adjustable temperatures with explenations of what that configuration does, i havent updated my files to actually check it out but i will shortly
powerstroked08
Pennsylvania
Yes the just added the tables. Its a little easier to understand what each temp is for now that I looked at it.
powerstroked08
Pennsylvania
They also added the tables just below that for the electric water pump for the fuel cooler.
Stroked777
Casper, Wyoming
It's funny your guys posted that about an update. I was laying in before I was going to sleep thinking if they updated MCC lately.... Is that a weird pre sleep thought?
Stroked777
Casper, Wyoming
wow just checking pout the update and its amazing, has controls for PATS and the coolant pump like you said, pats could solve lots of problems for people
powerstroked08
Pennsylvania
Hell my pre bed thoughts are usually "hmmm boobs (grab the womans) boy I wonder if I threw a 91mm infront of my tow X's and 60% nozzles with dual fuelers if I can break 900, oooh boobs again. Oh and what if I up the rail pressure and pull some PW at lower rpms? Ooh thats a nice @ss I should grab it again.... Hmmm maybe a new set of pistons?" :eek:fftopic
