Hard long start cold no start hot runs rough
ascrap2003
Did that are you talking about the plug on the 2 o clock position? Takes about 5 seconds to get halfway
ascrap2003
Its fine. Easiest way to check base engine oil pressure is to remove the oil filter cap and filter, use a long screw driver to press the BLACK not BRONZE spring loaded plug down and have someone turn over the engine while you hold that plug down. The oil filter housing should be a minimum half full 3 to 4 seconds into cranking the engine.
I also took a pressure reading from the gray sensor at about 10 o clock from the housing small gray sensor m12 threads takes a few seconds to get a readings of about 5 and after 5 seconds jumps to over 20psi
