kadeninabnitt
Im having issues starting the truck doesnt matter hot or cold. You try to start it and it wants to start but wont unless you are in the throttle, and once it does start it romps really bad unless you bring the throttle up just over idle for a little bit then it will quit romping. I mentioned my issue to my local dealer diesel tech and they said its likely the front cover leaking and draining my hpop res. Since i just put a manual trans back in the truck they said it puts more stress on the crank and causes this problem. Does this sound right i havent had time to mess with it yet where do i need to start and if it is the front cover what all would i need to replace?
