BFT
And for future comments... No smart a$$ remarks. Unfit is as easy as that and fixes our problems then I'm game.
Yes i have. Im also torture testing a set on my blue truck. Would you agree that 2200 degrees of exhaust temps are hot enough to test it?
The truck/ motor was built to specificly test it. Im pulling the heads off that motor in a few weeks. Thats 2200 degrees about 20 ish truck pulls in 2 months time. every pull was at that temp. Countless hot street runs az well.
Also plz explain your above qoute. I dont understand what you meant by it?
Not too start an argument but on my black truck most of the cracks started in the exhaust seats and were working thur way to some of these sharper edges you speak of. Not all but most.
I agree with Robert on this Kyle, usually you bring good info to the table but sometimes the way you come off says ass hole... Just being honest. And with some of your comments about how you know something others done looked pretty childish imho.... And I know i'm not the only one that saw it.
Just keep it on topic and thanks for sharing my next set of heads will have all the edges buffed off... Can't hurt that's for sure
I am in the process of doing this right now and let me tell you it is labor intensive.
Most good things are lol post some pics if you don't mind
I have 4 sets of heads to do right now. *** me.
Since you pride yourself in understanding what causes cracked heads/seats, what is your opinion on driving conditions that speed up cracking the most.... many miles (self explanatory), brief excessive EGTs (such as the 1/4 mile), sustained high EGTs (consistently running from 800 to 1200), very hot sustained EGTs followed by sudden drop in EGTs (such as towing up a long grade and then descending down the grade)?
All the engines ive pulled apart that had cracked heads were 6.0 and 6.4 with big tunes , injectors,etc.
The owners beat the **** out of them on a daily basis.
Heat is whats cracking the heads. Lots of it. Period. The driving habits leading to this?
Much time with the gogo pedal on the carpet, creating that heat.
Thanks. Related to this build (the OP uses his truck for heavy towing), one thing that has always had me concerned was when I am towing and climbing a long hill, the heads have to get pretty hot. If I immediately start descending when I get to the top of the hill, my EGTS drop quickly. Obviously the change in temps don't happen as quick as if you could throw cold water on them, but I was curious if the drop is sudden enough to promote cracking.
