89 Stroker
intake valve busted and a bad injector on my 97 7.3, so i need to remove the head, anyone have some detailed directions or something? any tips? anything to be aware of?
thanks a ton guys!!
thanks a ton guys!!
If you want to be able to move the engine and transmission you will have to undo the trans cross member and the motor mounts, but make sure you secure it well with 2x4's or something like that
Like someone else said, make sure you either have a engine hoist or in a pinch a section of 4x4, with chain around it and a couple buddies to lift the head on/off. My bathroom scale weighed each head at 115lb, so they aren't something you are going to be able to wrestle yourself without damaging the new gasket.
that is if i want/need to be able to move the motor
think twice about pulling the head in chassis. chances are that if you dropped a valve you have block damage and then you be pulling the engine anyway. I would pull the motor to do heads,,,, they are that heavy
