ATF Burner
I was changing out my glow plugs and I got 7 in no problem and the last one on the rear drivers side the outer part came off of the core. The core is still in there but I cannot get it out. The tip didn't break off as far as i can tell, only the top piece that the plug slips onto. I started the engine and it didn't budge it at all. It ran fine and didn't seem to be anything wrong. I am at a loss as what to do and I absolutely need the truck on Wednesday. How hard is it to pull the head off? Is it something that can be done in 2 days without having done it before? I'm pretty much freaking out here. And if I can get it, would it hurt to run the truck like this with the electrical plug secured so it doesn't short out?
