HELP homemade hpop setup problem
Magnum PD
VA
I got parts to do it, need to see how to do it right. I never ran my first one when I got it together
B.A.D Performance
But as soon as I hook it up to the stock pump ipr goes to 65% and builds 250psi thats it. Unhook the haldex truck fires up instantly
B.A.D Performance
But my thinking is even if the haldex is damaged wouldn't the truck still start off the stock hpop? The check valve keeps it from back feeding through the haldex.
Magnum PD
VA
Crazy thought:
Unless the Haldex is "pulling" oil from the stock pump. IDK
B.A.D Performance
Ill check tomorrow. I know for sure the problem is something with the haldex setup. Like I said it runs perfect on just the stock pump. Theres just something im missing
Magnum PD
VA
I need to know also. I gave you advice and need to help anyway I can and learn also.
B.A.D Performance
Funny you brought that up. I thought about that earlier. Im not sure the open pressure on that check valve. I just told the hydraulic shop I needed one. The never asked what open pressure I wanted. Ill have to check the part number
