Yes! Dont waste your time or money. Get it welded then scuff the new oil pan. Then paint the **** out of it with whatever you choose.
I used the same silver vht paint I used on the block. Then my buddy, ever the study, notices tons of little marks where the road had been flinging shti. So we stopped painting and grabbed a couple cans of duplicolor bedliner.
I have done a few worse then that. I've replaced numerous VCs that have rusted through and had a couple that head bolts were almost completely rusted off.
Toman if you do new manifolds don't use dormans.
Its doable though. If you can leave things slightly covered and pressure wash the **** out of it, that'll help. A lot.
Bet you have zero problem chasing down an oil leak.
I painted a small block Chevy engine pure white once. Looked pretty for a couple years. Ended up pulling it fixing some little leaks, and painting it black.
Sweet. Instant trouble lights. Make sure you aim one at the CPS.
that would be awesome!thats the inspiration for it...
My brothers truck he just "had" to buy. This is the side I torched off the bolt heads. Going to cut the driver side. Never in my life seen a truck rusted like this one. Had to weld nuts to 4 of them. Uppipe bolts fused into the manifolds well.
