help with issues on my "new" truck
jaybuller
I still feel you are low on the boost! however it may be in the tuning now. for reference I hit 35psi easy with my 160/30 injectors and a 38r. and that is with the waste gate bleeding off excess other wise it was over 40. I know nothing about the big bad turbo your running but it just sounds very weak to me at only 25 psi.
KingRanch6.0L
West Houston
So i got on it yesterday and noticed a fair amount of exhaust coming into the cab from the stick shift opening. Guessing I still have a rather large exhaust leak somewhere.
mandkole
Northwest
I suppose you could-- just need to cap the intake at the y pipe, otherwise the pressure goes out the air filter.
powerjoke73
I run 250/100% with stock fuel pump and it holds right at 60-62 so you should be fine there, but always check with the gauge to make sure it can keep up. However, you need a RR and other typical fuel mods.
