The beef:
First off this is my first post so go easy on me. I have a 2005 F350 powerstroke with about 208k on it. The only aftermarket done to it is 4 inch exhaust and I am running IDP Xtreme Street tune. It is not studded and does not have the egr delete done yet. I have the egr delete kit in the garage just have not had time to do the work yet. Oil and filters have about 5k on them and planning to change that out at about 7k....unless I should before. I used two bottles of Rev X in the oil change.
The problem:
So, every now and then I get a rough idle. It is very sporadic. I have no codes thrown at me yet. Normally it happens when the motor is getting warm but not always (like I said, it is sporadic). Low power when taking off but seems to be fine in the higher gears. Some times it clears out after a few miles of driving. It happened to me tonight so I pulled over and shut it off. As soon as I shut it off, I put key on and started back up and was perfectly fine. I am stumped....Any ideas would be great!
The problem:
