Do you have access to a scanner? If not find someone who does. DO you have a cel?
Mar 11, 2013 #21 TERRCO Member Joined May 18, 2011 Messages 781 Reaction score 1 Location Devine,Texas Do you have access to a scanner? If not find someone who does. DO you have a cel?
Mar 11, 2013 #22 ford_trck Member Joined May 18, 2011 Messages 447 Reaction score 0 Location Vail, AZ kystroker7.3 said: are you saying it may be bad? Click to expand... Yes
Mar 11, 2013 #23 kystroker7.3 New member Joined May 18, 2011 Messages 51 Reaction score 0 Location Lexington,Ky Is there a way to test it?
Mar 11, 2013 #24 ford_trck Member Joined May 18, 2011 Messages 447 Reaction score 0 Location Vail, AZ I honestly don't know. Matt had his go bad on his truck and was told to replace it he did and it started.
Mar 11, 2013 #25 Bugman Active member Joined Aug 20, 2011 Messages 1,293 Reaction score 6 Location Gypsum, Co You need to get your truck on a scanner, that is unless you plan on replacing parts until you get it running. If you just keep replacing parts you may run out of money before your truck starts to run again.
