littleredstroker
So swapped in a a motor bout a month month and a half ago. And been running fine till about a week ago, heard some squeaking to find that the water pump pulley was working its way loose. Ok, tightened back up and did it again, when it did it the second time i lost one of the bolts. I lock tited them on and tightened em up using the 3 till I could get hold of another bolt. Driving home last night, lose power steering and so i pull over and sure enough the belt was off ... And the
Water pump pulley had pulled off.. confusing part is all 3 bolts were tight still... It literally pulled the bolt heads through the pulley.. WTF is going on ??
Same exact water pump/pully/fan that had been ran for 200k.. brand new tensioner and idlers.. so confused.
sent while staring at a windowed block
