Derek@Vision Diesel
Im changing things up a little bit to get some more air.
Turbo is a hx55 holeset with about 50 miles on it since it was rebuilt. Spools great with 250/200s (could definitely go with smaller injectors though). Id say its pretty much a 500hp capable turbo on the 7.3, but could be used in much smaller applications.
66mm inducer
19cm exhaust housing with Internal wastegate (currently not being used)
Comes with bellowed up-pipes, turbo mount/pedistal, and custom down pipe. I will also include all the hardware to mount it.
Set up for an OBS.
Ready to install kit for $1400
PM me if you need any more info
66mm inducer
Set up for an OBS.
