m j
I think they said the Jr was 17° and stock pistons so it doesnt really compare to an increased displacement pump
For the Honey Badger JR: All cores are stripped down completely. The housing is drilled, ported and tapped in preparation for the modifications. A dowel pin is installed to keep the swash plate in place. All o-rings, springs, seals & bearings are replaced with new parts. All bushings are replaced with new ball bearings, all swash plates are 17*. All fittings are new. All pistons and cylinders are checked to make sure they are within spec. Each pump is assembled, serial numbered, and tested before they ship. A custom HPOP gear key-way can also be added to eliminate any chance of the shaft spinning inside the gear. All of our HPOPs ship with a mounting gasket, HPOP cover, and core paperwork.
The pistons are stock in the Honey Badger JR.
