Horsepower build lists?
6fodays
va
Just interested in trucks 600hp + trying to put together my build list and would like to hear track times and hp numbers for different builds.
6fodays
va
Im wanting like 800-900 dependably. Thinking single s472, 60% nozzles, dual hpfp, air dog, fuel bowl ******, studs, trans, ported rails, cam and valvetrain
Radioflyer
Huge difference between 600 and 8-900.
Agree'd. Your looking into bottom end work, more fuel and valve train upgrades for sure. I'd do rods, some people wouldn't agree, but it's good insurance since you will be pulling the bottom end apart anyways to do the pistons.
Yea but i was looking into what everyone at 600 was doing in comparison to people pushing 800+
600+ can easily be achieved with good tunes, head studs, drop in atmosphere turbo and a no limit intake. My 6.4 was high 600s but i also all the no limit air goodies, ported intake manifold, cam and 73/59 stock appearing chargers.
Dont forget the supporting goodies either...lpfp, traction bars, built trans etc.
800+ is gonna need my setup that i mentioned plus a dual fueler and 60% nozzles.
900+ needs a mega set of compounds like High powers or max powers if you like vgt. Or 66/88 (or similar sized) non vgt compounds to get there. BOSS450 is doing it with a big single and spray but even he says it isnt that awesome to drive on the street.
Your budget, goals and intended use are whats gonna set the recipe for your truck.
Jonnydime
Your post almost made me add up everything I have into my truck. For that reason I will not post a build list.LOLLOL
webb06
Seneca, MO
Did you get that sick feeling in your stomach after adding it all up....been there....LOLOLOLOL
btoler4th
Mt. Olive, NC
Fresh hpfp
Lpfp
All the air upgrades
72mm drop in
Done
Check out jdgleason's YouTube channel. He has multiple videos over the past few years with dyno proven combinations. For the above mentioned combo he put down almost 700. I've paid real close attention to them since before and after my build.
6fodays
va
Yea im definitely probably gonna run an s475, with 60's abd dual fuelers, and supporting mods, gonna try to tune it to keep around 800
btoler4th
Mt. Olive, NC
I heard that. That's a combo I'd like to run down the road ( or something close to it) A lot of big single trucks around here I need to keep in check. On the other hand, love the street manners of compounds. Hope it all works out for you.
bigrpowr
<How I Fly
a drop in 72 wont put you anywhere near 700 . 625 maybe , depends on the dyno and the day .
devdiesel
Barrie, Ontario
72-75 mm drop in with fuel and a weight reduction makes for lots of fun.. Then you can add spray to the mix... Might not make the huge fuel only numbers but it will run like stock and with good gate settings run awesome track times
