Horsepower
rwoods5
How much horsepower can the stock engine and transmission handle before needing to be beefed up?
ckrueg
Belding MI
I would think it's more the torque that kills the engines. That's why vgt and compound setups seem to break rods more. A big single will make less tq at the same hp level as a compound vgt setup
rwoods5
My truck is tuned with *******. It has been ******d and I have a MPD 364.5 SXE turbo kit, CCV kit, and no limit intake. What do I need to get to about 650 hp?
Jeremy @ No Limit
Athens, Ga
What year do you have? I assume 11-14. You can do a 15+ pump swap, Midwest Stroker pump or dual fuelers. Give us a call! We carry all of these!
SKYWALKR
Are the power limits mentioned here rwhp or at the crank? Also, if 600 is the limit it seems from the factory the 2015 is at 4xx hp.. we are flirting with that limit... even a ****** and tune could put us in the danger zone... true??
bigrpowr
<How I Fly
at the rear wheels . 700 rear wheel is danger zone . tune nowhere near the danger zone. lucky to make 550 with a tune .
Santa Fe NM
Not to hijack your thread but I am doing a similar build on my 6.7, 364.5sxe and dual fuelers. Does the low pressure fuel system need to be upgraded?
