House is having baby vehicle reduction sale!!!!!!!!!!!
House
Angola,In
Time to get ready for a kid in January!!!
1978 Ford 150 4x4 with rare 8ft step side bed.
I am the 3rd owner of the truck. It sat for 15 years before I got it when i was 16(now 27) at the time I had the body and paint, along with motor redone.
Truck has 70,800 Miles on it.
400m 2 barrel carb, 10k on over haul on motor, carb just rebuilt 2 weeks ago.
4 speed manual with center force dual friction clutch
9 inch rear with moser nodular case, aluminum pinon support, moser 31 spline axles, detroit locker, 3.55 gear
44 front with open diff, 3.55 gear, warn lock outs
4 inch rancho lift, rancho shocks, newer ford aluminum rims, 35 inch uniroyal mt's (2 30% 2 are slicks)
tube bumpers, front set up for winch
high idle switch in cab
set up for dual battery's but only has one battery in it.
rock proof steering system from http://bulletproofsteering.com/
Truck runs great, carb rebuilt i, fuel pump in last 3 months. The bad is the breaks do not work, i think power booster is bad. as I added a master cylinder a year ago and didn't fix the issue of hard pedal.
I have a new door that needs paint that goes with the truck and orginal door that goes along with to have matching locks. has a brown door on it now due to the fact the window track came off and bent.
I am asking $2000 OBO
http://www.facebook.com/media/set/?set=a.541885146243.2104570.58208478&type=1&l=66e77c6caa
2003 Gmc crew cab dually 4x4, 231k on it, needs injectors and possible head gaskets. Truck is all there will drive on a trailer. $6800 obo
http://www.facebook.com/media/set/?set=a.840318358693.2275376.58208478&type=3&l=ecf152babd
1995 F250 Extend cab long bed.. 7.3 Powerstroke 231K miles.. Runs great!!!
Now the extras! 1978 King Pin 60 under it.. 4.10 gears front and rear..
Use to be an automatic all the wiring and shifter is still there.. Has a 2000 Zf6 out of a F350 in it with 100k miles on it.. Clutch is a new Kennys Machine Big Single Disc rated for 700 Hp or heavy towing...
Engine Mods.. Stage 1 160cc injectors, Custom T4 turbo mount kit with a S465 turbo on it, spools great.. Regulated return fuel system, Supert duty Eletric fuel pump and Cat filter. Superduty Intercooler. Have comp 910-16 valve springs just need installed if want to play hard.
3.5 inch down pipe to 4 inch exhaust.
Tschip 6 position with swamps tunes.
Truck has a gooseneck hitch in it, bumper hitch, power windows and locks, Interior is clean.. Boost, Pyro gauges
What it needs.. Front drive shaft lengthened, and rims and tires.. Its sitting on steel rims and mix matched tires.. This might be a kicker for some people the hvac system is gone, I still have the air condition compressor and lines, The heater box on firewall and blower motor is MIA and panels over the holes.. All one would need is to get a heater box and blower motor and reinstall it and hvac would work again.
Asking $4800 FIRM If some one was wanting this for a serious toy or pulling truck, I do have an 2000 Dana 80 Dually axle with 4.10 gears and springs Id sell for another 800$
The body is really clean only a few small spots of rust..
http://www.facebook.com/media/set/?set=a.649459845683.2202851.58208478&type=3&l=e0b33c6fdf
Fs/trade 1979 GMC Prostreet drag/show truck
1979 GMC Pro Street Drag Truck
+ 468 Cubic Inch Big Block Chevy
-Forged Crank and Rods
-Keith Black Forged Pistons
-10.5:1 Compression
-Ultradyne Hydralic Cam
-LS6 Heads
-Weind X-CELATOR intake
-Holley 750 Double Pumper Chokeless Race Carb
-Headman Full Tube Headers, 1 3/4"
-GM HEI Ignition
-Hypertech Coil
-Nitrous Express 50-300HP adjustable nitrous kit, with
purge, installed, never used
-Professionally built by Hedricks Precision Engines in
Champaign, IL
+ GM TURBO 400
-Built by Coan
-10 inch 3500 stall Coan Converter
-Hurst Quarter Stick Shifter
+ Chasis
-Factory Chassis, back-halved
-Competition Engineering Ladder Bars
-A.R.T. (Applied Racing Tech) Adjustable coilovers rear
-3 inch Belltech drop spindles
-Competition Engineering Wheelie Bar
-Narrowed Ford 9 inch
-Strange 33 Spline Spool
-Moser 33 Spline Axle Shafts
-Moser 4.30 Ring and Pinion
+ Interior
-Grant GT Steering Wheel
-Billet Dash Inlays
-Auto Meter Sport Comp Series Gauges:
-3 3/4" Tachometer
-Liquid filled Oil Pressure and Water Temp
-Autometer Pro-Shift Light
-Auto Meter Pro Controller
-New Black Carpet
-Black Bench Seat
-Sony 6x9 Speakers
-Dennon AM/FM Cassette
-Sliding rear window
-Tinted windows
+Body
-Harwood Cowl Induction Hood
-Tubbed Bed
-Herculined inner bed sides
-Rubber Bed Mat
-Shaved side mirrors
-Tube Grill
-Black Out Headlights
-Roll Pan
-Small dent on drivers front fender (see pics)
-Scratch on passenger side door
+Wheels and Tires
-15x7 Weld Pro Stars in front
-15x15 Weld Pro Stars Rear, drilled and tapped for screws
-31x16.5-15 Mickey Thompson Sportsman rear tires
-Comes with un mounted 33x16-15 Goodyear Drag Slicks and Tubes
Truck has less than 500 miles on it since built, well kept in climate
controlled storage unit. Ran very little, never raced, only shown at
local car shows. Lost interested in this truck for another project.
Insurance appraised this truck at $25,000 asking $12,000 obo
http://rides.webshots.com/album/281865560LhmkWu?start=0
