RedRice589
Exactly as it says, i traded my Dpf off my old truck for a 4 inch downpipe and 5 inch exhaust with a 6 inch black MBRP tip. What are the secrets to get the downpipe off? Thx
Just undo from the turbo and wiggle it down as far as you can and cut it above the crimp with a good size metal sawzall blade.
Sweets thanks guys and no i will not pull the cab to do it even though it is considerably easier... although if i drop the trans i could do it and the oil cooler rigght? Or am i mistaken? I know the oil cooler is usually done with headstuds just wondering if i can get to it without pulling the cab.
