how to prevent your 6.7 from making the "diesel rattle" noise???
morepower02
MN
My 15 duramax started to make a sound today that might sound like a diesel. Not sure as the exhaust makes no sound but under load it rattles a little. It's predecessor the 7.3 and 6.0 were so quiet not sure what to do.
dsmracing1
Alberta, Canada
Try a Cetane booster. I use Amsoil Cetane booster and add it to my Howe's fuel conditioner. Before I didn't use a Cetane booster and I got a lot of extra racket. Purrs like a kitten now....
jcain
Amsoil cetane didn't do **** for my truck, but their injector cleaner + cold flow did wonders. So now I just use Ford pm22 during the warmer weather.
Additives...lol...
Noise...lol
Whackin it is the only true, given thing in this thread.
knaffie
I have. It seems to help some, but definitely doesn't keep it away 100%.
6.7s are loud? I parked next to one at a gas ststion once and couldnt hear it over the sloppy hpfp in my duramax.
CATDiezel
The OP has never owned a 7.3L
The trucks do gradually get louder from new. As the engine breaks in alittle noise becomes more present. You may also be hearing a passive regen. It's a small regen not noted on the dash.
The noise is directly related to injection timing. It's just the nature of the beast.
knaffie
I haven't owned a 7.3, but rode in plenty of them. What does that have to do with anything?
Its not passive regen causing the noise.
If injection timing is it, then that just sucks.
Dzchey21
wyoming
i would bet 100 bucks its the EGR,
If you have someone that has a good scan tool that can monitor EGR duty cycle see if the noise follows the EGR cycle. ALso a good way to check is to command 30% EGR duty cycle and see if the noise sounds about the same.
