Enoch
- Joined
- May 19, 2011
- Messages
- 272
- Reaction score
- 0
Is there a way to tell if shop really performed a compression check?
I was told:
All cylinders have super low compression
38R is shot (So needs new turbo) turbo has about 50k-60k miles on it
Valve cover harness is shot
Engine is pretty much dusted and would need a rebuild (Minimum of $10,500 probably more)
What it has:
330k miles
38r turbo
4" exhaust
Big air filter
SCT tune (plug in play)
Stock injectors
Stock valve cover harness
My complaint when taking it in:
Lags power on low end and speeds
Smokes few minutes on cold starts
Slow to start (like 3-5 seconds) when cold
It kind of feels like it sputters or chugs up hill, helps when overdrive is off.
It has no leaks, no blow by, and only smokes first start. It does not blow white smoke or any smoke at normal operating temps.
It uses very little oil between oil changes.
Options I was given.
Complete rebuild $10,500+
Injectors, turbo, harness $3k+
Put back together with new harness $800
So is there a way I can tell if this shop really did a compression check?
I was told:
What it has:
330k miles
38r turbo
4" exhaust
Big air filter
Stock injectors
