HPODS or not?
smokinstroker
Texas
then dont pull it from the bottom. pull it from the side. problem solved.
I'm just talking about how warren had his, and said his hooked up. Not talking about fixing the problem with his kit.
Yes it's an easy fix, just saying the bottom of the pan would not be my first choice
TooMuch03
West Bend, WI
Next question. I think Elite's Dual HPOP draws from somewhere above the LPOP and I heard they were having problems with it drying up the LPOP over 4200 rpm or something. Does anyone know how the Elite dual HPOP is routed? Is it routed to the oil rails or to the test port like Warren's, or some other way?
Pizza pig
MD
do you really think the lpop is going to be starved of oil with such a low volume pusher pump? I like the pan idea the best.
6.0 p-stroke
North of San Antonio, Tx
it depends on how much oil you're pulling from the lpop, but it isn't anything new for dual hpops to suck the lpop dry, which is why people are starting to draw oil from the pan I believe.
Edit: elite might have found a fix to this since there are more dual hpops setups running now
