HPOP Gaskets Leaking - \
rrchlin
I figured it was a line.
sometimes you think you know too much! like blaming an HPOP cause you got 2 more.
I was going to order a new set of lines to be safe. Would I just be a cheapass to order https://www.ebay.com/itm/KBDP-HPOP-...riorityMailPaddedFlatRateEnvelope!08016!US!-1
They're not steel braided like OEM. Riffraff has OEM for $200.
Also is Joey that builds the Terminator HPOPS still in business? I see them on different sites for sale but can't find a direct site for him. I was figuring sending in him the T-500 in case it still leaks out of the back plate would be worth it.
Optimator82
Greenacres, WA
The lines need to be rated to handle the constant heat cycles and pressure of the hpop system and standard hydraulic line is not. I'd be hestiant that the ones found on eBay unless OEM are made with suitable rated hose to be used on these trucks for the hpop system. I would look at getting a set from Corey at CNC Fab. They are priced less than OEM ones from Ford and they are made with the proper rated hose.
