HPOP gear access cover kit
Arisley
Arlington, Texas
My EBP tube and sensor have been broken for years. Just decided to replace them. If you are going to replace, why not improve if possible.
Got this kit from Dennis. Perfect fit, easy install.
Thanks for not forgetting us old Dinosaur drivers Dennis.
TyCorr
I too made the plunge a while ago. When you buy a part from Dennis you start wondering what the oem designers were thinking. You will absolutely love that part Andy. I used stock style bolts just because I dont like having to use a different tool to remove the fasteners that hold the cover on. But that was user preference not a design issue as the allen head SS bolts would look MUCH nicer!
Arisley
Arlington, Texas
I also used the factory bolts, for the same reason. It will make it so much easier to get to the HPOP front bolt now.
Strictly Diesel
Phoenix
Thanks guys! I hope you both at least used the washers I included, so the flange head on the stock bolts doesn't tear up the nice finish on the front of the cover.
