HS-Motorsports 08-10 Ford 6.4L Wastegate Kit
Keep the head gaskets in your motor with our 6.4 wastegate kit. The factory turbos on these trucks produce an insane amount of back pressure in the exhaust system and cause many trucks to blow head gaskets. Our wastegate will relieve unnecessary pressure and help make turbos last longer as well as eliminate the need for head studs in mildly fueled trucks. The kit is 100% bolt on and can be done in less than a couple of hours.
I've had quite a few people ask me if the 6.4 Wastegate Kit will work with our turbo kit as well. Essentially, as long as you are using the factory up pipes, it will work on any turbo setup as it mounts to the driver's side pipe.
If you are running our 6.4 Single Turbo Kit, you can also use our Universal Wastegate Kit and mount the wastegate on the provision we machine into the cast elbow.
The Universal Wastegate Kit can also be used on many other applications with a little bit of fab work.
http://hs-motorsports.com/misc-products/universal-wastegate-kit.html
