HS-MotorsportsZane
- Joined
- Aug 8, 2013
- Messages
- 469
- Reaction score
- 0
We are very close to release our new low pressure fuel system for the 6.7 Powerstroke. We have been testing these system's extensively on a few different applications and power levels of 6.7 trucks for the past 6 months now, with great result's. They are set up as a regulated return system with the ability to set the fuel pressure to your desired level. The system can be installed on a single CP4 injection pump engine (stock), or a dual high pressure fuel injection pump application with just a few simple change's of supplied fuel line plumbing. The HSM fuel pump/primary fuel filter assembly mount's directly in the factory location with no drilling or modification/cutting of any of the factory fuel lines, making it a very clean simple install. The pump is rated at 150 gph which supplies plenty of fuel volume for stock and modified application's, and is backed with a two year warranty. Here are a few pics we took months ago..... I will try and get some updated install pics here when we get a little more time. Thanks!
