Cowboy Troy
I have a 03 6.0 with a bad FICM and I wanted the bulletproof one but its only for 04.5 and newer. I know swamps makes one but you have to send in your old one and they fix it. Who else sells a good one?
Why 58v?
I seen their storage room they have tons LOL
but even if they parted with one it would need programed for your truck
Nope. Swap the board in and go
I don't agree the logic side needs to Be programmed
I even offered to buy a complete unit and they confirmed that the power supply is the easy side the other half would need programed to the truck
Ahhh hell i caused a dispute! :doh:
well actually a used logic board may have the wrong programing for the intended donor so it may need re programed to work
but if it's the original half shell from the truck then swap and roll .. but these guys needing the 4 pin will likely need a FICM flash
no dispute just good ole conversation
