Power Strokes
7.3 Aftermarket
I think I am defueling at 24psi...
[QUOTE="Charles, post: 582797, member: 103"] The Map sensor is just a sensor... All it does is report a voltage to the PCM based on input pressure. The PCM and it don't have any sort of power struggle or anything like that. When the Map sensor reports a voltage equal to ~24psi to a PCM running a stock Ford calibration for at least _____ seconds the PCM will set a SES light and reduce power as it is programmed to do. If you simply change the parameter in the calibration of the PCM that explicitly tells it to set a SES and defuel when the Map sensor reports a pressure of _____ psi, then it will not happen. The Map sensor is doing it's job, and the PCM has been instructed by the Ford software to reduce power and alert the operator that a problem is occuring via a SES light. For years we solved the problem by disallowing the Map sensor to ever see this value, and that in turn kept the PCM from doing what it was told, setting a SES and reducing power. The files I wrote for my 550 do not set the light, nor do they defuel thanks to a little tip from Matt at Gearhead. Those were the first files of mine that did not require a map sensor fooler. [/QUOTE]
Truck slipping into 4th
Latest: ju015dd
46 minutes ago
6.7 Tech
DEF in the fuel tank of 2013 F250 6.7
Latest: Crazy Canuck
Monday at 12:05 PM
6.7 Tech
I
Tuning the 7.3 in current times
Latest: INFRNL
Monday at 9:28 AM
7.3 Aftermarket
2000 f350 dually lariat
Latest: ju015dd
Monday at 8:19 AM
7.3 Aftermarket
Best turbo upgrade in current times?
Latest: 6.0 Tech
Sunday at 11:01 PM
7.3 Aftermarket
blackbeauty7.3
Blitzin247
hermantile
phenopd
Power Strokes
7.3 Aftermarket
